К Алексею обращайтесь, он может взяться за это безобразие.)
 NanoBeam M2-400, перестал работать Wi-Fi, веб-интерфейс ругается на "Flash memory failure detected". Пинг проходит. Прошил через tftp на XW.v5.5.10-ct.bin - стало ругаться на Conterfeit. С другими прошивками веб вообще не поднимается. Флешка под замену?
 Лог загрузки UART:
 Код:U-Boot 1.1.4-s751 (Aug 21 2013 - 12:06:27) Board: Ubiquiti Networks AR9342 board (e2c2-82.1122.0030) Reset: Normal DRAM: 64 MB Flash: 8 MB (0xef, 0x40, 0x17) Net: AR8032 Detected eth0 Radio: 0777:e2c2 Hit any key to stop autoboot: 0 ## Booting image at 9f050000 ... Image Name: MIPS Ubiquiti Linux-2.6.32.60 Created: 2014-10-01 13:43:31 UTC Image Type: MIPS Linux Kernel Image (lzma compressed) Data Size: 1000836 Bytes = 977.4 kB Load Address: 80002000 Entry Point: 80002000 Verifying Checksum at 0x9f050040 ...OK Uncompressing Kernel Image ... OK Starting kernel ... Booting Atheros AR934x
 Лог прошивки tftp со сбросом настроек:
 Код:U-Boot 1.1.4-s751 (Aug 21 2013 - 12:06:27) Board: Ubiquiti Networks AR9342 board (e2c2-82.1122.0030) Reset: Normal DRAM: 64 MB Flash: 8 MB (0xef, 0x40, 0x17) Net: AR8032 Detected eth0 Radio: 0777:e2c2 Hit any key to stop autoboot: 0 Setting default IP 192.168.1.20 Starting TFTP server... Using eth0 (192.168.1.20), address: 0x81000000 Will reset device configuration (Reset button active after 10 seconds). find_mtd_part Clearing partition 'cfg': erasing range 0x9F7B0000..0x9F7EFFFF: .... done Erased 4 sectors Waiting for connection: | Receiving file from 192.168.1.252:52401 Received 6736659 bytes Firmware Version: XW.ar934x.v5.5.10.24238.141001.1641 Setting U-Boot environment variables Un-Protected 1 sectors Erasing Flash.... done Erased 1 sectors Writing to Flash... write addr: 9f040000 done Protected 1 sectors Will not overwrite u-boot partition! Skipped. Copying partition 'kernel' to flash memory: erasing range 0x9F050000..0x9F14FFFF: ................ done Erased 16 sectors writing to address 0x9f050000, length 0x00100000 ... write addr: 9f050000 Copying partition 'rootfs' to flash memory: erasing range 0x9F150000..0x9F69FFFF: .................................................. ................................... done Erased 85 sectors writing to address 0x9f150000, length 0x00550000 ... write addr: 9f150000 Firmware update complete. Resetting...
 Здравствуйте,UBNT PicoStation M2 , работала, как точка долго, недавно начала терять ланпорт, помогала перезагрузка по питанию,
 тепери вообще не отвечает, горит светодиод питания, на Ресет не реагирует, не пингуется. Читал,что мож быть дело в диодах/транзисторах, либо в самой м/с ланпорта.В разобраном состоянии сильно греется радиатор,обжигает.Подскажите с чего начать, принципиальную схему не могу найти, чтоб знать какие диоды/транзисторы установлены.Прошу помочь со схемой.
 Никакая схема тут не поможет, откис ЦП AR7240/7241, только его замена.Сообщение от xo6uyc Посмотреть сообщениеЗдравствуйте,UBNT PicoStation M2 , работала, как точка долго, недавно начала терять ланпорт, помогала перезагрузка по питанию,
