поставил проц 7240. Результат тот же. флешку перепрошивал программатором - не помогло. :wacko:
Сейчас грид был с такой болячкой. помогло прогрев и небольшое покачивание оперативки , но все равно ,
Проходит загрузка ,диод лан молчит.U-Boot 1.1.4.2-s594 (Dec 5 2012 - 15:23:07)
Board: Ubiquiti Networks XM board (rev 0.1 e242)
DRAM: 32 MB
Flash: 8 MB
PCIe WLAN Module found (#1).
Net: eth0, eth1
Hit any key to stop autoboot: 0
## Booting image at 9f050000 ...
Image Name: MIPS Ubiquiti Linux-2.6.32.54
Created: 2013-05-28 14:56:15 UTC
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 1047584 Bytes = 1023 kB
Load Address: 80002000
Entry Point: 80002000
Verifying Checksum ... OK
Starting kernel ...
Booting...
[ 0.000000] Linux version 2.6.32.54 (buildd@builder) (gcc version 4.1.2) #1 T ue May 28 17:56:11 EEST 2013
[ 0.000000] flash_size passed from bootloader = 0
[ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 00800000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 -> 0x00000800
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00000800
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pa ges: 2032
[ 0.000000] Kernel command line: console=ttyS0,115200 root=31:03 rootfstype=s quashfs init=/init mtdparts=ar7240-nor0:256k(u-boot),64k(u-boot-env),1024k(kerne l),6528k(rootfs),256k(cfg),64k(EEPROM)
[ 0.000000] PID hash table entries: 32 (order: -5, 128 bytes)
[ 0.000000] Dentry cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 5020k/8192k available (2289k kernel code, 3172k reserved, 539k data, 136k init, 0k highmem)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:128
[ 0.000000] plat_time_init: plat time init done
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] Calibrating delay loop... 259.58 BogoMIPS (lpj=129792)
[ 0.016000] Mount-cache hash table entries: 512
[ 0.019000] NET: Registered protocol family 16
[ 0.021000] ===== ar7240_platform_init: 0
[ 0.021000] PCIe WLAN H/W found [tries: 1]
[ 0.021000] PCI init:ar7240_pcibios_init
[ 0.021000] ar7240_pcibios_init(368): PCI CMD write: 0x356
[ 0.021000] registering PCI controller with io_map_base unset
[ 0.030000] bio: create slab <bio-0> at 0
[ 0.032000] usbcore: registered new interface driver usbfs
[ 0.032000] usbcore: registered new interface driver hub
[ 0.033000] usbcore: registered new device driver usb
[ 0.034000] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 0.034000] pci 0000:00:00.0: PME# disabled
[ 0.034000] Returning IRQ 48
[ 0.035000] Switching to clocksource MIPS
[ 0.038000] NET: Registered protocol family 2
[ 0.038000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.040000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[ 0.040000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[ 0.040000] TCP: Hash tables configured (established 512 bind 512)
[ 0.040000] TCP reno registered
[ 0.041000] NET: Registered protocol family 1
[ 0.041000] AR7240 GPIOC major 0
[ 0.043000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.043000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY ) (c) 2001-2006 Red Hat, Inc.
[ 0.044000] msgmni has been set to 16
[ 0.044000] io scheduler noop registered (default)
[ 0.069000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.071000] serial8250.0: ttyS0 at MMIO 0xb8020000 (irq = 19) is a 16550A
[ 0.372000] console [ttyS0] enabled
[ 0.377000] 6 cmdlinepart partitions found on MTD device ar7240-nor0
[ 0.383000] Creating 6 MTD partitions on "ar7240-nor0":
[ 0.389000] 0x000000000000-0x000000040000 : "u-boot"
[ 0.395000] 0x000000040000-0x000000050000 : "u-boot-env"
[ 0.402000] 0x000000050000-0x000000150000 : "kernel"
[ 0.408000] 0x000000150000-0x0000007b0000 : "rootfs"
[ 0.414000] mtd: partition "rootfs" set to be root filesystem
[ 0.420000] 0x0000007b0000-0x0000007f0000 : "cfg"
[ 0.426000] 0x0000007f0000-0x000000800000 : "EEPROM"
[ 0.433000] usbmon: debugfs is not available
[ 0.437000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.444000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.451000] u32 classifier
[ 0.454000] Performance counters on
[ 0.458000] input device check on
[ 0.461000] Actions configured
[ 0.467000] TCP westwood registered
[ 0.471000] NET: Registered protocol family 10
[ 0.480000] NET: Registered protocol family 17
[ 0.484000] Bridge firewalling registered
[ 0.488000] 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
[ 0.495000] All bugs added by David S. Miller <davem@redhat.com>
[ 0.501000] ar7240wdt_init: Registering WDT success
[ 0.517000] VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
[ 0.525000] Freeing unused kernel memory: 136k freed
[ 0.543000] Please be patient, while AirOS loads ...
[ 1.692000] Algorithmics/MIPS FPU Emulator v1.5
...mounts done
...filesystem init done
...base ok
...update ok
...symlinks ok
...httpd ok
...detect ok
...caldata ok
...running /sbin/init
и тут бах и ресет
и поехало
DRAM: 32 MB
Flash: 8 MB
Net: eth0, eth1
Starting kernel ...
Booting...
[ 0.415000] mtd: partition "rootfs" set to be root filesystem
[ 1.693000] Algorithmics/MIPS FPU Emulator v1.5
[ 1.712000] Kernel bug detected[#1]:
[ 1.712000] Cpu 0
[ 1.712000] $ 0 : 00000000 00000001 00000001 00000000
[ 1.712000] $ 4 : 804cff20 00000003 2aaa8aa0 2aaa8aa0
[ 1.712000] $ 8 : 804336a0 80101da8 2aaed0d8 00000054
[ 1.712000] $12 : 00000002 80300000 000000c0 00000004
[ 1.712000] $16 : 80419d20 804cff20 8044e530 00000000
[ 1.712000] $20 : 804dabc0 2aaa8000 80771f30 804dbaf4
[ 1.712000] $24 : 00000000 800109c0
[ 1.712000] $28 : 80770000 80771dc8 804d40a0 8008382c
[ 1.712000] Hi : 000001b6
[ 1.712000] Lo : 0001b0b9
[ 1.712000] epc : 80040504 commit_creds+0x3c/0x1ac
[ 1.712000] Not tainted
[ 1.712000] ra : 8008382c install_exec_creds+0x18/0x34
[ 1.712000] Status: 1000ff03 KERNEL EXL IE
[ 1.712000] Cause : 10800034
[ 1.712000] PrId : 00019374 (MIPS 24Kc)
[ 1.712000] Modules linked in:
[ 1.712000] Process mount (pid: 194, threadinfo=80770000, task=8044e530, tls= 00000000)
[ 1.712000] Stack : 804dabc0 00044ffc 80771f30 804dbaf4 00000000 800109c0 800 00000 00002012
[ 1.712000] 80770000 80771e10 804dabc0 804d4160 804dbac0 8008382c 804 dbac0 00000000
[ 1.712000] 80771e30 804d4160 80771e30 800b6c78 80082134 00000001 000 02000 00000001
[ 1.712000] 00002012 00000000 804dabc0 00000001 0000000d 00000007 000 0000d 2aaed140
[ 1.712000] 2aaed0d8 00000006 804daac0 004c3828 004c2000 00481df8 004 00000 2aaa8aa0
[ 1.712000] ...
[ 1.712000] Call Trace:
[ 1.712000] [<80040504>] commit_creds+0x3c/0x1ac
[ 1.712000] [<8008382c>] install_exec_creds+0x18/0x34
[ 1.712000] [<800b6c78>] load_elf_binary+0xc7c/0x11f4
[ 1.712000] [<80082414>] search_binary_handler+0x90/0x294
[ 1.712000] [<80083b90>] do_execve+0x180/0x29c
[ 1.712000] [<800093a4>] sys_execve+0x4c/0x78
[ 1.712000] [<8000d1c4>] stack_done+0x20/0x3c
[ 1.712000]
[ 1.712000]
[ 1.712000] Code: 00038036 8c820000 28420001 <00028036> c2240000 24840001 e2240000 108000d6 00000000
[ 1.712000] Disabling lock debugging due to kernel taint
[ 1.902000] Kernel panic - not syncing: CRED: put_cred_rcu() sees 804cff20 wi th usage -1
[ 1.902000]
--И дело та в том что шью флешак запаиваю в другой грид работает. запаиваю в этот грид и вот такая бяка. и сколько бы я не шил все одно и то-же.[ 1.902000] Kernel panic - not syncing: CRED: put_cred_rcu() sees 804cff20 wi th usage -1
Еще заметил , если отключить БП из сети , то свитч показывает как будто есть подключение.Ремонт оборудования Ubiquiti и Mikrotik
Стоп:
С какого перепугу 64Мб? Или я отстал от жизни и в них уже не по 32 ставят?Сообщение от greenday Посмотреть сообщениеNanostation m2 загрузка останавливается на
U-Boot 1.1.4.2-s445 (Sep 6 2010 - 14:46:33)
Board: Ubiquiti Networks XM board (rev 1.0 e2b5)
DRAM: 64 MB
Да я уже все что можно поменял , и транс и диоды снял , точка была до меня в ремонте , меняли проц , видимо по пути отвалилась рама , прогрел раму завелась , доходит вот до этого и алле .Сообщение от Yuraner Посмотреть сообщениеЛёш, супрессоры сняты надеюсь? А так - проц(85%) vs рама(15%).
А свитч видать у меня такой , на прямую в комп не работает.Ремонт оборудования Ubiquiti и Mikrotik
У меня на 32 не было микросхемы. Что было рабочее то и припаял. Планка есть DDR 400 на ней 4 чипа по 64. Успешно опробованы на дир 320 и на NS M5. Раньше стояло 32. Но замена ничего не дала. Я уже и прозвонил все дорожки от проца к памяти, но пока ничего.Сообщение от Yuraner Посмотреть сообщениеСтоп:
Всем доброго дня! Возник вопрос! Есть Air Grid M5 с битым лан портом, лан порт восстановил (перебросом на другие ножки проца), точка пингуется и пускает на веб морду, но вопрос в том что индикация лана на самой точки не горит и в веб морде пишет что лан не подключен и соответственно не рисует график. Я так понимаю дело осталось за программной переделкой?
Пропал контакт от 2 ноги проца в сторону памяти.припаял перемычку и заработало.Сообщение от greenday Посмотреть сообщениеУ меня на 32 не было микросхемы. Что было рабочее то и припаял. Планка есть DDR 400 на ней 4 чипа по 64. Успешно опробованы на дир 320 и на NS M5. Раньше стояло 32. Но замена ничего не дала. Я уже и прозвонил все дорожки от проца к памяти, но пока ничего.
Ну да, джипио же настроено на другой порт.Сообщение от perevozhik08 Посмотреть сообщениеВсем доброго дня! Возник вопрос! Есть Air Grid M5 с битым лан портом, лан порт восстановил (перебросом на другие ножки проца), точка пингуется и пускает на веб морду, но вопрос в том что индикация лана на самой точки не горит и в веб морде пишет что лан не подключен и соответственно не рисует график. Я так понимаю дело осталось за программной переделкой?
у меня рокет с такой же бедой.Сообщение от Yuraner Посмотреть сообщениеНу да, джипио же настроено на другой порт.
Понятно что проц надо поменять. Это вообще не проблема. Но мы легких путей не ищем. :derisive:Сообщение от Алексей Посмотреть сообщениеВы чего заморачиваетесь та, пришлите я вам отремонтирую и все ок будет. а этот геморрой не надолго. Поверьте.
