Парни помогите:
установил для теста следующую прошивку: Tanaza , всё работает прекрасно но не могу восстановиться обратно на оригинал или OpenWRT.
точка сидит в Bootloop,а если снова прошить Tanaza то всё работает,в чём проблема?
Received 7534209 bytes
done
Protected 1 sectors
Will not overwrite u-boot partition! Skipped.
Copying partition 'kernel' to flash memory:
First 0x5 last 0x14 sector size 0x10000
Setting U-Bootd 1 sectors
.. done
write addr: 9f050000
Firmware Version: ipped.
Copying partition 'kernel' tCopying partition 'rootfs' to flash memory:
First 0x15 last 0x7a sector size 0x10000
.................................................. .............................................. done
write addr: 9f150000
Flash: 8 MB
U-Boo MB
PCIe WLAN Module found (#1).
.4.2-s9d (#1).
0 2015 - 10:54:50)
DRAM: 32 MB
Firmware update comple#1).
0 2015 - 10:5eth0, eth1
Board: Ubiquiti Networks XM board (rev 1.0 e012)
Hit any key to stop autoboot: 0
## Booting image at 9f050000 ...
OK
Image Name: MIPS Ubiquiti Linux-2.6.32.68
Created: 2015-11-30 15:50:17 UTC
OK
Starting kernel ...
Booting...<0>
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 1005326 Bytes = 981.8 kB
Load Address: 80002000
Entry Point: 80002000
Verifying Checksum ...
Flash: 8 MB
U-Boot B
.4.2-und (#1).
0 2015 - 10:54:50)
DRAM: 32 MB
eth0, eth1
OK
OK
Starting kernel ...
Received 3408284 bytes
Setting U-Boot environment variables
Un-Protected 1 sectors
Erasing Flash.... done
Erased 1 sectors
Writing to Flash... done
Protected 1 sectors
.. done
Firmware Versiotected 1 sectors
First 0x15 last 0x6e sector size 0x10000
.................................................. .................................... done
U-Boot 1.1.4.2-s956 (Jun 10 2015 - 10:54:50)
DRAM: 32 MB
Flash: 8 MB
FirmwaN Module found (#1).
OK
Image Name: MIPS Tanaza Linux-3.3.8
Created: 2015-10-28 10:12:40 UTC
OK
259.27 BogoMIPS (lpj=1296384)
[ 0.670000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
[ 1.910000] ag71xx-mdio.1: Found an AR7240/AR9330 built-in switch
[ 1.340000] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
q 5, mode:GMII
[ 2.950000] TCP cubic registered
[ 2.960000] NET: Registered protocol family 17
[ 2.960000] Bridge firewalling registered
[ 4.700000] Registered led device: ubnt:red:link1
o update world regulatory domain
[ 5.510000] cfg80211: World regulatory domain updated:
[ 7.530000] Netfilter messages via NETLINK v0.30.
[ 8.270000] Newly-erased block contained word 0xdeadc0de at offset 0x00390000
[ 8.280000] Newly-erased block contained word 0x314d043e at offset 0x00380000
[ 9.790000] Newly-erased block contained word 0xdeadc0de at offset 0x00000000
[ 9.800000] done.
[ 9.800000] JFFS2 notice: (714) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
Jan 1 00:00:12 tanazad[843]: device version: 2.5.9
Jan 1 00:00:12 tanazad[843]: device model: nanom
[ 13.480000] cfg80211: World regulatory domain updated:
[ 13.480000] cfg80211: DFS Master region: unset
[ 15.170000] device eth0 entered promiscuous mode
[ 13.490000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 16.330000] device wlan0 entered promiscuous mode
[ 16.380000] br0: port 3(wlan0) entered forwarding state
[ 17.360000] eth0: link up (100Mbps/Full duplex)
[ 17.360000] br0: port 1(eth0) entered forwarding state
[ 18.370000] br0: port 1(eth0) entered forwarding state
[ 17.370000] br0: port 1(eth0) entered forwarding state
[ 17.390000] br0: port 3(wlan0) entered forwarding state
[ 170000] br0: port 1(eth0) entered forwarding state
[ 13.490000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.500000] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.510000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.520000] cfg80211: (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.530000] cfg80211: (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 13.540000] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 13.540000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 13.550000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
пробовал много прошивок - не помогло:bad:
Спойлер (+/-) (Log XM.v5.6.3.28591.151130.1749 :)
done
Protected 1 sectors
.. done
Flash: 8 MB
U-Boo MB
.4.2-s9d (#1).
0 2015 - 10:54:50)
DRAM: 32 MB
OK
OK
Starting kernel ...
Booting...<0>
Flash: 8 MB
U-Boot B
.4.2-und (#1).
0 2015 - 10:54:50)
DRAM: 32 MB
eth0, eth1
OK
OK
Starting kernel ...
Спойлер (+/-) (Log Tanaza:)
Erased 1 sectors
Protected 1 sectors
.. done
DRAM: 32 MB
Flash: 8 MB
OK
OK
q 5, mode:GMII
[ 9.800000] done.
