Не любите чистый Linux, пользуйтесь Cygwin под Windows
d-link 2100 не исправен
создал учётку в винде root запустил оттуда программу, но серавно пишет что файл не найден в директорииСообщение от _q6_ Посмотреть сообщениеможет это
JTAG Tools 0.6-cvs-20051228
Copyright (C) 2002, 2003 ETC s.r.o.
JTAG Tools is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
There is absolutely no warranty for JTAG Tools.
Warning: JTAG Tools may damage your hardware! Type ''quit'' to exit!
Type ''help'' for help.
jtag> cable parallel 0x378 WIGGLER
Initializing Macraigor Wiggler JTAG Cable on parallel port at 0x378
jtag> detect
IR length: 5
Chain length: 1
Device Id: 00000000000000000000000000000001
Unknown manufacturer!
chain.c(110) Part 0 without active instruction
chain.c(133) Part 0 without active instruction
jtag> include atheros/ar2312/ar2312
jtag> poke 0x58400000 0x000e3ce1
ImpCode=01000000010000000100000000000000
EJTAG version: 2.6
EJTAG Implementation flags: R4k ASID_8 NoDMA MIPS32
jtag> detectflash 0x1fc00000
dev ID=007e man ID=0001
Using CFI flash chip detection, not jedec
Query identification string:
Primary Algorithm Command Set and Control Interface ID Code: 0x0002
(AMD/Fujitsu Standard Command Set)
Alternate Algorithm Command Set and Control Interface ID Code: 0x0000 (null)
Query system interface information:
Vcc Logic Supply Minimum Write/Erase or Write voltage: 2700 mV
Vcc Logic Supply Maximum Write/Erase or Write voltage: 3600 mV
Vpp [Programming] Supply Minimum Write/Erase voltage: 0 mV
Vpp [Programming] Supply Maximum Write/Erase voltage: 0 mV
Typical timeout per single byte/word program: 128 us
Typical timeout for maximum-size multi-byte program: 128 us
Typical timeout per individual block erase: 1024 ms
Typical timeout for full chip erase: 0 ms
Maximum timeout for byte/word program: 256 us
Maximum timeout for multi-byte program: 4096 us
Maximum timeout per individual block erase: 16384 ms
Maximum timeout for chip erase: 0 ms
Device geometry definition:
Device Size: 4194304 B (4096 KiB, 4 MiB)
Flash Device Interface Code description: 0x0002 (x8/x16)
Maximum number of bytes in multi-byte program: 32
Number of Erase Block Regions within device: 2
Erase Block Region Information:
Region 0:
Erase Block Size: 8192 B (8 KiB)
Number of Erase Blocks: 8
Region 1:
Erase Block Size: 65536 B (64 KiB)
Number of Erase Blocks: 63
дошёл до этого теперь нужно залить файлы. файл скачал оттудаже но куда его в папку программы скопировать чтобы она нашлась при команде flashmem 0x1fc00000 2100.boot
jtag> flashmem 0x1fc00000 /tmp/2100.boot
Chip: AMD Flash
Manufacturer: Unknown manufacturer (ID 0x0010)
Chip: Unknown (ID 0x0000)
Protected: 0001
program:
flash_unlock_block 0x1FC00000 IGNORE
block 0 unlocked
flash_erase_block 0x1FC00000
flash_erase_block 0x1FC00000 FAILED
erasing block 0: 99
flash_unlock_block 0x1FC02000 IGNORE
block 1 unlocked
flash_erase_block 0x1FC02000
flash_erase_block 0x1FC02000 FAILED
erasing block 1: 99
addr: 0x1FC02000
пока идёт чёто но пишет FAILED это значит непроходит прошивка ?
jtag> flashmem 0x1fc00000 2100.boot
Unable to open file `2100.boot'!
jtag> flashmem 0x1fc00000 /2100.boot
Chip: AMD Flash
Protected: 0001
program:
block 0 unlocked
erasing block 0: 99
addr: 0x1FC00000
положил в корень тоже самое
