Значь так. Кончаем тему размазывать. Посты по существу и без лишней лирики.
_________________
Убрал лишнее
kuslik
_________________
_________________
Убрал лишнее
kuslik
_________________
U-Boot 1.1.3 (Jan 7 2010 - 19:12:59) (Alpha) - SVN revision : 260
Model: WAPN09
bootcode version v1.00 r005
Board: RT2880 DRAM: 32 MB
config usb..*** Error: D+/D- is 1/1, config usb failed.
twe0 set to <NULL>
toe0 set to <NULL>
Ralink UBoot Version: 3.1 Alpha
ASIC 3052_MP2 (MAC to GigaMAC Mode)
DRAM COMPONENT: 256Mbits
DRAM BUS: 16BIT
Total memory: 32Mbytes
Date:Jan 7 2010 Time:19:12:59
icache: sets:128, ways:4, linesz:32 ,total:16384
dcache: sets:128, ways:4, linesz:32 ,total:16384
## Powering down port 0 ~ 3.
Please choose the operation:
1: Load system code to SDRAM via TFTP.
2: Load system code then write to Flash via TFTP.
3: Boot system code via Flash (default).
4: Entr boot command line interface.
9: Load Boot Loader code then write to Flash via TFTP.
You choosed (50)
0 seconds ...
Eth0 (10/100-M) : ethaddr = (1c:bd:b9:ab:e8:48) 1C BD B9 AB E8 48
## Powering up port 0 ~ 3.
2: System Load Linux Kernel then write to Flash via TFTP.
Please Input new ones /or Ctrl-C to discard
Input device IP (192.168.0.50) :
Input server IP (192.168.0.20) : 192.168.0.129
Input Linux Kernel filename () : dlink.1T1R.1.1.22.RU.05102010.bin
Warning!! Erase Linux in Flash then burn new one. Are you sure ? (Y/N)
BusyBox v1.12.1 (2010-02-01 11:46:16 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
. : break cd chdir continue eval exec exit export false hash
help local pwd read readonly return set shift source times trap
true type ulimit umask unset wait
# cat /proc/cpuinfo
system type : Ralink SoC
processor : 0
cpu model : MIPS 24K V4.12
BogoMIPS : 255.48
wait instruction : yes
microsecond timers : yes
tlb_entries : 32
extra interrupt vector : yes
hardware watchpoint : yes
ASEs implemented : mips16 dsp
VCED exceptions : not available
VCEI exceptions : not available
# ps
PID USER VSZ STAT COMMAND
1 admin 1432 S init
2 admin 0 SWN [ksoftirqd/0]
3 admin 0 SW< [events/0]
4 admin 0 SW< [khelper]
5 admin 0 SW< [kthread]
6 admin 0 SW< [kblockd/0]
7 admin 0 SW< [kswapd0]
8 admin 0 SW< [aio/0]
9 admin 0 SW [mtdblockd]
17 admin 1084 S nvram_daemon
18 admin 1536 S goahead
22 admin 1432 R telnetd
24 admin 1436 S /bin/sh
140 admin 0 SW [RtmpWscTask]
240 admin 1428 S udhcpc -i eth2.2 -s /sbin/udhcpc.sh -p /var/run/udhcp
486 admin 1432 S udhcpd /etc/udhcpd.conf
662 admin 1428 S klogd
1263 admin 1440 S -sh
1289 admin 1432 R ps
# cd /bin
# ls
zebra rt2860apd nvram_get kill dnsmasq
wscd rm nvram_daemon iwpriv date
vi ripd ntpclient iptables cp
upnpd reg mtd_write inadyn cat
upnp_xml.sh ralink_init mount igmpproxy.sh busybox
touch ps mkdir igmpproxy ated
switch pptp mii_mgr grep ash
sleep pppd ls gpio
sh ping login goahead
sed nvram_set lld2d echo
# cd /sbin
# ls
wifi_unload.sh pppoe-manual-off.sh halt
wan.sh poweroff global.sh
vpn-passthru.sh ntp.sh firewall.sh
vconfig nat.sh ddns.sh
udhcpc.sh lsmod config.sh
udhcpc logread config-vlan.sh
syslogd lan.sh config-udhcpd.sh
route l2tpd config-pptp.sh
rmmod l2tp.sh config-pppoe.sh
reboot l2tp-control config-l2tp.sh
radvd klogd config-igmpproxy.sh
pptp.sh internet.sh config-dns.sh
pppoe.sh insmod chpasswd.sh
pppoe-relay init
pppoe-manual-on.sh ifconfig
