Всем привет. Имеется данная точка. В прекрасный момент перестала работать. Через консоль выдает
U-Boot 1.1.3 (Apr 23 2009 - 12:08:20)
Board: Ralink APSoC DRAM: 32 MB
relocate_code Pointer at: 81fb0000
flash_protect ON: from 0xBF000000 to 0xBF01D3C3
flash_protect ON: from 0xBF030000 to 0xBF030FFF
*** Warning - bad CRC, using default environment
Ralink UBoot Version: 3.3
ASIC 3052_MP2 (Port5<->None)
DRAM component: 128 Mbits SDR
DRAM bus: 32 bit
Total memory: 32 MBytes
Flash component: NOR Flash
Date:Apr 23 2009 Time:12:08:28
icache: sets:256, ways:4, linesz:32 ,total:32768
dcache: sets:128, ways:4, linesz:32 ,total:16384
##### The CPU freq = 384 MHZ ####
SDRAM bus set to 32 bit
SDRAM size =32 Mbytes
Please choose the operation:
1: Load system code to SDRAM via TFTP.
2: Load system code then write to Flash via TFTP.
3: Boot system code via Flash (default).
4: Entr boot command line interface.
9: Load Boot Loader code then write to Flash via TFTP.
You choosed 3
0
3: System Boot system code via Flash.
## Booting image at bf050000 ...
Image Name: Acorp_WR-300N
Created: 2011-10-06 23:01:17 UTC
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 3506982 Bytes = 3.3 MB
Load Address: 80000000
Entry Point: 80220000
Verifying Checksum ... OK
No initrd
## Transferring control to Linux (at address 80220000) ...
## Giving linux memsize in MB, 32
Starting kernel ...
Linux version 2.6.21.7 (sfstudio_at_mail.ru@wive-ng.sf.net) (gcc version 4.5.3 (
GCC) ) #0 Fri Oct 7 05:48:45 OMSST 2011
ASIC mode LINUX started...
The CPU frequency set to 384 MHz
CPU revision is: 0001964c (MIPS 24K)
DetectRAMsequence
MAX memory:[64]
RAM after first pass:[67108864]
RAM after second pass:[33554432]
FullviewRAM:[33554432]
Determined physical RAM map:
memory: 02000000 @ 00000000 (usable)
Built 1 zonelists. Total pages: 8128
Kernel command line: console=ttyS1,57600n8 root=/dev/mtdblock4 ro
start_kernel(): bug: interrupts were enabled *very* early, fixing it
Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Primary data cache 16kB, 4-way, linesize 32 bytes.
Synthesized clear page handler (25 instructions).
Synthesized copy page handler (44 instructions).
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
Cache parity protection disabled
cause = d0808008, status = 11000000
PID hash table entries: 128 (order: 7, 512 bytes)
calculating r4koff... 0005dc00(384000)
CPU frequency 384.00 MHz
Using 192.000 MHz high precision timer.
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 30140k/32768k available (63k kernel code, 2628k reserved, 1982k data, 22
4k init, 0k highmem)
Mount-cache hash table entries: 512
set cpu_wait to r4k_wait
softirq RT prio: 24.
NET: Registered protocol family 16
Time: MIPS clocksource has been installed.
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
ralink flash device: 0x400000 at 0x1f000000
Ralink SoC physically mapped flash: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
Creating 7 MTD partitions on "Ralink SoC physically mapped flash":
0x00000000-0x00030000 : "Bootloader"
0x00030000-0x00040000 : "Config"
0x00040000-0x00050000 : "Factory"
0x00050000-0x00105366 : "Kernel_stub"
0x00105366-0x003e0000 : "RootFS_stub"
0x003e0000-0x00400000 : "RW-FS"
0x00050000-0x003e0000 : "Kernel_RootFS"
Load Timer Module(Wdg/Soft)
NVRAM: Kernel NVRAM start init.
squashfs: version 3.4 (2008/08/26) Phillip Lougher
squashfs: LZMA suppport for slax.org by jro
io scheduler noop registered (default)
Ralink gpio driver initialized
Number of GPIO=52
Generic RTC Driver v1.07
Ralink APSoC Hardware Watchdog Timer
Serial: 8250/16550 driver $Revision: 1.6 $ 2 ports, IRQ sharing disabled
serial8250tyS1 at I/O 0xb0000c00 (irq = 12) is a 16550A
Ralink APSoC Ethernet Driver Initilization. v2.1 512 rx/tx descriptors allocate
d, mtu = 1500!
NAPI enable, weight = 64, Tx Ring = 512, Rx Ring = 512
PROC INIT OK!
block2mtd: version $Revision: 1.1.1.1 $
nf_conntrack version 0.5.0 (16384 buckets, 4096 max)
TCP cubic registered
ip_tables: (C) 2000-2006 Netfilter Core Team, Type=Fully Cone
NAT Fastpath init.
NET: Registered protocol family 17
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
VFS: Mounted root (squashfs filesystem) readonly.
Freeing unused kernel memory: 224k freed
mount /proc file system ok!
mount /sys file system ok!
mount /dev file system ok!
mount /var file system ok!
HN`L`^@^N``NB^@D@H@ ^@HN`L`^@^Nbpb^@D@H@^@^H^@LN^@\^L^H^@^@\^@^@^^^@^@ ^@\^@^
@^^@\\^@^X^P^^@^@^^^@^@^^@^@^@^@^^@^@^^@^^@^@^@^@\ ^@^@^@^@\^@\\^@^@^^@\^@^@^@\^@
X\^@PX^@^@^P@^@\^@X^@P\^@^@\^@^X\^@^@^@^@^@^^^@Alg orithmics/MIPS FPU Emulator v1
.5
^@^@HFN`H``@ABb ^@^@\^@^@^@^^^@^@\^@^@^@\^@^@\^@^X\^@^@^@\^@^X\^@^ @\^@^@\^@^@^@
phy_tx_ring = 0x015f6000, tx_ring = 0xa15f6000
phy_rx_ring0 = 0x015f8000, rx_ring0 = 0xa15f8000
CDMA_CSG_CFG = 81000007
GDMA1_FWD_CFG = 710000
ttyS1: 1 input overrun(s)
Не дает зайти в режим прошивки. Проскакивает, сама выбирает режим 3: Boot system code via Flash (default).
Кто нибудь сталкивался с такой проблемой? Как можно вылечить?
PS. Точку цеплял com кабелем на MAX232
DRAM bus: 32 bit
You choosed 3
0
No initrd
Starting kernel ...
DetectRAMsequence
MAX memory:[64]
TCP reno registered
Number of GPIO=52
d, mtu = 1500!
PROC INIT OK!
NAT Fastpath init.
.5
