    BlueBox это увеличение ACK Timeout в устаревших стандартах 802.11 b/g
    https://www.air-stream.org/technical...distance-links
    ACK Timeout: Clearly if the ACK timeout is shorter than the time it takes for the end of the last data packet (+ SIFS) to propagate to the receiver + the start of the ACK for that packet to propagate back to the sender, then the sending MAC will assume that the packet has been lost and will unnecessarily retransmit the data packet. The retransmitted packet will end up colliding with the ACK that is on its way back, inducing the back-off part of the protocol thus reducing throughput. If, conversely, the ACK timeout is set too long, the transmitter waits unncesessarily long before retransmitting any lost frames and thus reduces the throughput of the link (more important as the bit error of the environment increases.) Similar conclusions can be drawn about the CTS timeout, however RTS/CTS is only for reducing collisions with hidden nodes and can be turned off in the majority of cases. Most implementations assume the IEEE recommended one-way Air Propagation Time of 1 µs, thus tune the ACK Timeout of their devices to 300 meters. This is the maximum distance that high throughput can be achieved between a local network of IEEE 802.11b compliant devices out of the box. The links will still work over longer distances, but throughput will drop as the distance increases.
    В стандарте 802.11n был предложен новый механизм Block-ACK. Проблема, потому что фреймы группируются в блоки по 64 штуки.
    Block-ACK Mechanism. Rather than sending an individual acknowledge following each data frame, 802.11n introduces the technique of confirming a burst of up to 64 frames with a single Block ACK (BA) frame.
      yurik82, на постсоветском пространстве разве нет никаких других источников , чтоб апеллировать и отправлять?
      Блин, мне как кишлачному, кажется снг центром мирового развития, где язык межнационального общения является русский. Только что овладел русским, но уже новые вызовы на английском. Вот, куда таким как я, кишлачному деваться? Далее деревенским и хуторским ? мы не бачим по англицки
        Форумчане, а какой аппарат нужен для дальних приемо-передач ?
        Для мостов тплинк841 (каких то двух версий - там радио не интегрир а отдельно) и 3420v1. В опенврт их( чтоб клиент там, мост и т. д.) До 10км точно- ток нацелить оочен сложно!
          Сообщение от Voodoo Doll Посмотреть сообщение
          И ни слова о том, как работает PCB патч медью внутрь? То есть, между патчами и экраном 6 мм именно воздуха и ничего больше.
          При 1.5 мм FR4:
          1) ДН размазывается в пятно, направленность этого пятна снижается с 18 dBi до 8...11 dBi
          2) тепловые потери на разогрев PCB 1.5-3 дБ, с учётом КПД Ку=7...10 dBi
          3) Сопротивление излучения снижается с 50-60 до 20...30 Ом, реактивность растёт до +j40...80 Ом, КСВ растёт с 2-3 до 4...8
            Приобрел вместо фа 20 антенну АНП-24 производство Киев за 200 грн(в рублях 400) и идеальном состоянии б/у Ну да лучше в разы сигнал поднялся но огромная против "фа".Не знаю как там сделан облучатель(лохопериодичка) но пока что доволен.
            Последний раз редактировалось Elektrix; 15.01.2018, 17:50.
              Если исправить проблемы фазирования то усиление может составить:
              * 18.7 dBi = только коробка с 25 мм бортами
              * 20.0 dBi = +100 мм рупор @ 18
              * 21.0 dBi = +200 мм рупор @ 20
                Принципиально новая заготовка на 8 патчей по типу FA-20:
                - плоская коробка 420x220x20 mm
                - крышка ПВХ
                - 8 круглых патчей по 64 мм из 0.5 мм оцинковки
                - болтами М5 прикручивается на пластиковые проставки высотой 6.0 мм
                - полосковые линии из медной проволоки 4 мм2
                - трансформаторы с выходом на 100 Ом - 30х0.5 мм полоса на высоте 4.0 над рефлектором
                осталось ещё придумать суммирующую линию на 100 Ом и тройник
                  Типа так получиться
                  http://www.lan23.ru/forum/showthread.php?t=12762
                    Собирал 15V4, успешно выполняет свои задачи, спасибо форуму за нюансы изготовления и прочие практические заметно важные моменты в изготовлении.
                    Добросовестно пытался осилить ЭТУ тему (антенна интересна), после четырех десятков страниц топика убогость изложения и языковая безграмотность "ораторов" топика вызвала стойкий рвотный рефлекс и комплекс неполноценности от факта, что я тоже "с Кубани". Всем видна эта "быдлопосредственность", это формирует отношение в целом.
                    Давайте будем стараться быть грамотнее в письме, даже для двоечников есть некоторые посредственные он-лайн инструменты.
                    Не давайте повода людям стыдиться своими земляками...
                      conler я доработал 15V4 до получения 17 dBi, при этом она получается значительно проще в производстве чем FA-20, а усиление такое же
                          Я уверен, что винты заземления в центре патчей делают VSWR выше ... По крайней мере, происходит на CST sim, и этот парень измерял 1,2 без винтов ...
                            прозрачная пленка для печати на струйных принтерах:
                            обращался к тем, кто занимается распечаткой - они не опознают.
                            думал заказать такую
                            https://aliexpress.ru/item/32788991210.html ,
                            но у нее пропорции другие на вид. на рисунке здесь - более квадратные.
                            вопрос: что за пленка? есть в китае?
                            спасиб
                              Я печатаю на лазернике. Потом затемнитель негатива Density Toner. Есть мелкие фирмы торгующие всем для печати. Пленку матовую белую и Toner беру в одном месте. Чтобы вывести из P CAD 2006 негатив использую экспорт/импорт через gerber формат, эта инструкция ( это под плёнку, под фоторезист в балончиках инвертировать цвета не надо). Дальнейший процесс фотолитографии имеет много тонких особенностей ненужных антенщикам . Раньше делал замену цвета Паинтом, но часто масштаб сбивается. Чтобы сделать шаблон для двухсторонней платы лист сначала прогоняется в пустую для усадки под нагревом. На больших форматах плат всё равно есть расхождения в печати нижней и верхней стороны. Из нескольких печатей можно подобрать лучшее совпадение для двухстороннего шаблона.
                              Пример
                                1. есть ли разница, где делать выход антенны?
                                Нажмите на изображение для увеличения.  Название:	81efc55675db8a7e255178e0e5b0fbc3.png Просмотров:	0 Размер:	138.1 Кб ID:	321738
                                Нажмите на изображение для увеличения.  Название:	73b85c84608d3e4bc88923d862c6426a.png Просмотров:	0 Размер:	93.8 Кб ID:	321739
                                2. обведено
                                Нажмите на изображение для увеличения.  Название:	34bc11475f0e7b98497e70c85c396c08.png Просмотров:	0 Размер:	22.1 Кб ID:	321740
                                3. делаю по этому мануалу
                                https://www.youtube.com/watch?v=3zHXu2EXVEc
                                за 80 страниц этой темы было ли добавлено в этот мануал что-либо (существенное)?
