if i use one side FA-20 20 dbi Antenna. so can i get signal over 1.5 Km if sight is not line of site and antenna not visible after 0.75 Km. or i can achieve what rate of speed i will get....it will be around 5-6 Mb. or if sight is not line of sight so i can receive how far...means 1 Km or little bit more 1 Km or till visible of antenna. and if i get signal over 1.5 km so what speed i will get.. i know it wont be 5-6 mb but guess how speed will i get.. aprox 2 mb is possible....?
FA-20 20 dbi Antenna Signal Over 1.5 Km is Possible.?
...........................Сообщение от true.friends.here Посмотреть сообщениеif i use one side FA-20 20 dbi Antenna. so can i get signal over 1.5 Km if sight is not line of site and antenna not visible after 0.75 Km. or i can achieve what rate of speed i will get....it will be around 5-6 Mb. or if sight is not line of sight so i can receive how far...means 1 Km or little bit more 1 Km or till visible of antenna. and if i get signal over 1.5 km so what speed i will get.. i know it wont be 5-6 mb but guess how speed will i get.. aprox 2 mb is possible....?
http://www.lan23.ru/wifi/example/exa1/exa1.html
Check it....You will get Yours answer here
