Панельная 3G антенна
    ,,, немного анимации ....
      ,,, CHANGE АДАПТАЦИЯ ЛИНИИ сопротивление...
      и добавление стен отражатель стороны!
        Good day JoMy!
        Today I collect all materials: steel – 1mm and 0.5mm, wire – 2mm, sma connector and Teflon, but have unplanned job.
        Thanks for moderator, what open new theme, is may be interesting for more another peoples.
        When I open new theme, the first time I see new idea and found inside the project how you organized new connection between patches and Hollywood’s animation – very nice. Also I see additionally information from jass66 about 5mm connection strap for wide band.
        Yesterday I was thoroughly investigated yours drawings and do not have any question and ready to make this antenna. But today I see progress inside the project for increased dBi and characteristics. And I think to take time out. Ok, will we see and so thanks if you put drawings for new idea with new strap.
        Последний раз редактировалось oveco; 04.12.2012, 18:20.
          Спасибо руководству, что организовали отдельную тему. Ваш сайт пользуется заслуженной репутацией, мои слова основываются на анализе, когда с других сайтов переадресуют как правило, к вам. Да и тема будет полезна нашим народным умельцам.
            ,,, эллипсы Другой вариант питания...
              Good day JoMy!
              I see the gain is wideband stable inside the new project with different of strap (powered) shape.
              Also I found interesting information about simulation program same as CST by reading book - (Antennas for Base Stations in Wireless Communications). The simulation and actually measured data almost in same positions. Is best! And I hope for make normal antenna without measuring procedures with yours new project. I stay online!
              Последний раз редактировалось oveco; 06.12.2012, 17:55.
                Good day to you , Oveco!
                I see your pictures, and I'm curious where you got the diagrams ...???!!!
                I understand that you still want the latest version of the antenna panel???
                  Yes, of course!
                  I like action, I like new ideas. The last project is enough for us just now. I recognized all new elements inside the last shape with new straps, but required all dimensions
                    ,,, ok, I sends them to you, wait a minute ...!!!
                    I have to draw and post antenna sizes ...!!!
                      ,,,Oveco,they are promised drawings...
                        Jomy! Thank you very match for you relationships!
                        I download new dimensions of antenna. Quickly analyzed and collect one picture, see attm. File.
                        I have one question (only for future): is not critical for “hobby” antenna, what VSWR in the working range >1.5 – 2.0 or it is difficult adjusting in the wideband range?
                          Сообщение от oveco Посмотреть сообщение
                          ,,, yes Oveco, I know that SWR should be within the range of < 1,5...2, and it is not difficult...!!!
                          In the future, I'll try to get fit in this range!
                            Lipton - Панель 15 V4 (модификация Бестер сектор) - Страница 4, # 39
                            …КСВ в диапазоне, не будет превышать, в худшем случае (криво установленные, косые блины), уровень 1,5-2 (что вполне достаточно для нормальной работы).
                            Если для знатоков не критично, то для меня, на данном этапе – тем более. Но подожду доработок от JoMy (т.к. материалов почти нет).
                            Lipton - Панель 15 V4 (модификация Бестер сектор) - Page 4, # 39
                            …, the VSWR level - 1.5-2 (is enough for normal operations). At this time, for me, also. But I wait modification from you JoMy. I hope – tomorrow beginning today.
                              ,,, Oveco, может быть так, но это, кажется, уменьшает эффективность антенны...
                                Good evening, JoMy!
                                We make this antenna and checked in operation, but in the evening time – at this place the wireless internet very busy, will be see in day time. Thanks for all!
                                Добрый вечер всем!
                                Антенна изготовлена и приступила к испытаниям. Сейчас вечер и Малайзийский интернет загружен, но результаты обнадеживающие. Протестируем завтра. Спасибо всем!
