Прошил,но криво, как исправить?, ПОМОГИТЕ!!!
    Друзья может что не так сделал, и как исправить?
    заранее огромное спасибо за ответы.
    DD-WRT> ^C
    DD-WRT> ip_address -h 192.168.1.2
    IP: 192.168.1.1/255.255.255.0, Gateway: 0.0.0.0
    Default server: 192.168.1.2
    DD-WRT> fis init
    About to initialize [format] FLASH image system - continue (y/n)? y
    *** Initialize FLASH Image System
    ... Erase from 0xbffe0000-0xbfff0000: .
    ... Program from 0x80ff0000-0x81000000 at 0xbffe0000: .
    DD-WRT> load -r -b 0x80041000 linux.bin
    Using default protocol (TFTP)
    TFTP timed out 1/15
    Can't load 'linux.bin': operation timed out
    TFTP timed out 1/15
    TFTP timed out 1/15
    TFTP timed out 1/15
    Raw file loaded 0x80041000-0x803ddfff, assumed entry at 0x80041000
    DD-WRT> fis create linux
    ... Erase from 0xbfc30000-0xbffcd000: .................................................. ........
    ... Program from 0x80041000-0x803de000 at 0xbfc30000: .................................................. ........
    DD-WRT> fconfig boot_script true
    boot_script: Setting to true
    Update RedBoot non-volatile configuration - continue (y/n)? y
    DD-WRT> fconfig boot_script_timeout 3
    boot_script_timeout: Setting to 3
    DD-WRT> fconfig bootp false
    bootp: Setting to false
    DD-WRT> fconfig
    Run script at boot: true
    Boot script:
    Enter script, terminate with empty line
    >> fconfig
    >> fis load -l linux
    >> exec
    Boot script timeout (1000ms resolution): 3
    Use BOOTP for network configuration: false
    Gateway IP address:
    Local IP address: 9600
    Local IP address mask:
    Default server IP address:
    Console baud rate: 9600
    GDB connection port: 9000
    Force console for special debug messages: false
    Network debug at boot time: false
    DD-WRT> reset
    Последний раз редактировалось AssassinChild; 22.02.2010, 17:36.
    Расскажите как делали, или на ddwrt форуме есть русскоязычная ветка.
