Фото заводских патчей.www.compress.ru/article.aspx?id=17784&iid=822
TP-LINK TL-ANT - 6dBi
Эта тема закрыта.
Разобрал настольную антенну Tp-Link 6dBi, вот что внутри корпуса...
http://www.tp-link.com/products/product_spe.asp?id=60
6dBi 2.4GHz Indoor Desktop Directional Antenna
Complies with 2.4GHz 802.11b/g/n standards
Provides 1m extension cable
Complete Plug & Play Instructions;
Works with all the wireless devices with reverse SMA connectors
Flexible deployment to improve signal transmission and reception
Electronic specifications & Parameters
Frequency Range 2.4GHz~2.5GHz
Impedance 50 Ohms
Gain (peak) 6.0dBi typ.(excluding cable loss)
VSWR 1.92 : 1 Max
Polarization Linear, Vertical
Beamwidth (HPBW) Horizontal: 45°
Vertical: 45°
Connector SMA Plug Reverse
Cable SMA Plug Reverse
Radiation directional
Admitted Power 1 W
Application Indoor
Mount Style Wall Mount / Desktop
Survival Wind Speed 216Km/hr(134Miles/hr)
Lighting Protection DC Ground
Mechanical Parameters
Dimensions (L x W x H mm) 80 x 80 x 158mm
Operating Temperature -10C~60C(14F~140F)
Storage Temperature -10C~70C (14F~158F)
Operating Humidity 10%~90% non-condensing
Storage Humidity 5%~90% non-condensing
Safety, Emission and others CE, FCC, Compliant with RoHSПоследний раз редактировалось Aristika; 01.04.2009, 14:01.
