Страница 4 из 4 ПерваяПервая ... 234
Показано с 31 по 36 из 36
Тема: Широкополосный диполь GSM-900
  1. #31
    Co-Модератор Аватар для uve
    Адрес
    Харьков
    Post Thanks / Like
    Вес репутации
    98
    По умолчанию
    Yurik82, не понял Ваших рассуждений. В данном случае LumpedPort выступает, как резистивная нагрузка 106 Ом. Что она может возбудить?
  2. Спасибо Vodkaman сказали спасибо
  3. #32
    Местный
    Адрес
    Kiev
    Post Thanks / Like
    Вес репутации
    15
    По умолчанию
    LumpedPort: и нагрузка и генератор, по принципу взаимозаменяемости.
    Если как нагрузка, то центральная жила - свободновисячая в пространстве волновода, нагружена одним концом на 106 Ом.
    Lumped ports:
    Lumped ports are similar to traditional wave ports, but can be located internally and have a complex user-defined impedance. Lumped ports compute S-parameters directly at the port.The complex impedance Zs defined for a lumped port serves as the reference impedance of the S-matrix on the lumped port. The impedance Zs has the characteristics of a wave impedance; it is used to determine the strength of a source, such as the modal voltage V and modal current I, through complex power normalization. (The magnitude of the complex power is normalized to 1.) In either case, you would get an identical S-matrix by solving a problem using a complex impedance for a lumped Zs or renormalizing an existing solution to the same complex impedance.
    By default, the interface between all 3D objects and the background is a perfect E boundary through which no energy may enter or exit. Wave ports are typically placed on this interface to provide a window that couples the model device to the external world.
    Wave ports:
    HFSS assumes that each wave port you define is connected to a semi-infinitely long waveguide that has the same cross-section and material properties as the port. When solving for the S-parameters, HFSS assumes that the structure is excited by the natural field patterns (modes) associated with these cross-sections. The 2D field solutions generated for each wave port serve as boundary conditions at those ports for the 3D problem. The final field solution computed must match the 2D field pattern at each port.
    HFSS generates a solution by exciting each wave port individually. Each mode incident on a port contains one watt of time-averaged power. Port 1 is excited by a signal of one watt, and the other ports are set to zero watts. After a solution is generated, port 2 is set to one watt, and the other ports to zero watts and so forth.
    WavePort вдувает в волновод мощность с какого-то возбудителя не показанного на схеме. если диаметр волновода позволяет на этой частоте ещё поддерживать определенную моду волны
  4. #33
    Адрес
    Харьков
    Post Thanks / Like
    Вес репутации
    98
    По умолчанию
    Всё равно не понял. В коаксиальном кабеле возбуждается волна ТЕМ. При установке порта волнового или сосредоточенного назначается интегральная линия указывающая точки приложения напряжения генератора( сосредоточенный порт) или направление вектора эл. поля( волновой порт). Для коаксиального кабеля оба порта дают почти идентичные результаты расчётов.
    И что значит нагрузка и генератор взаимозаменяемы? У них разные функции в этой схеме.
  5. #34
    Местный Аватар для Vodkaman
    Адрес
    KO85AD
    Post Thanks / Like
    Вес репутации
    143
    По умолчанию
    Там не “Lumped Port”, там Lumped Element, по простому - сопротивление.
    Смотри пост#25.
  6. Понравилось yurik82 понравился пост
  7. #35
    Местный
    Адрес
    Kiev
    Post Thanks / Like
    Вес репутации
    15
    По умолчанию
    к Lumped никаких замечаний нет, к жиле и оплетке что-то соединено электрически.
    вопрос к WavePort
  8. #36
    Адрес
    KO85AD
    Post Thanks / Like
    Вес репутации
    143
    По умолчанию
    Допилил вариант с трансформатором из 75 Омного кабеля. Надо сказать гемор еще тот, влияет все, и кабель за трансформатором, и внешняя изоляция, и толщина оплетки. Короче, этот вариант тоже по приборам только можно настроить, но настройка гораздо сложнее.
Похожие темы
  1. Широкополосный патч
    от uve в разделе Антенны диапазона 2,4ГГц
    Ответов: 127
    Последнее сообщение: 17.05.2014, 23:46
  2. Широкополосный сектор 3G
    от baxmud2 в разделе Новичкам
    Ответов: 4
    Последнее сообщение: 16.03.2014, 09:31
  3. Двойной диполь
    от jomy в разделе Моделирование антенн
    Ответов: 5
    Последнее сообщение: 28.03.2012, 21:04
  4. Горизонтальный диполь
    от Шифровщик в разделе Новичкам
    Ответов: 6
    Последнее сообщение: 24.12.2008, 10:55
