Широкополосный диполь GSM-900
    Yurik82, не понял Ваших рассуждений. В данном случае LumpedPort выступает, как резистивная нагрузка 106 Ом. Что она может возбудить?
      LumpedPort: и нагрузка и генератор, по принципу взаимозаменяемости.
      Если как нагрузка, то центральная жила - свободновисячая в пространстве волновода, нагружена одним концом на 106 Ом.
      Lumped ports:
      Lumped ports are similar to traditional wave ports, but can be located internally and have a complex user-defined impedance. Lumped ports compute S-parameters directly at the port.The complex impedance Zs defined for a lumped port serves as the reference impedance of the S-matrix on the lumped port. The impedance Zs has the characteristics of a wave impedance; it is used to determine the strength of a source, such as the modal voltage V and modal current I, through complex power normalization. (The magnitude of the complex power is normalized to 1.) In either case, you would get an identical S-matrix by solving a problem using a complex impedance for a lumped Zs or renormalizing an existing solution to the same complex impedance.
      By default, the interface between all 3D objects and the background is a perfect E boundary through which no energy may enter or exit. Wave ports are typically placed on this interface to provide a window that couples the model device to the external world.
      Wave ports:
      HFSS assumes that each wave port you define is connected to a semi-infinitely long waveguide that has the same cross-section and material properties as the port. When solving for the S-parameters, HFSS assumes that the structure is excited by the natural field patterns (modes) associated with these cross-sections. The 2D field solutions generated for each wave port serve as boundary conditions at those ports for the 3D problem. The final field solution computed must match the 2D field pattern at each port.
      HFSS generates a solution by exciting each wave port individually. Each mode incident on a port contains one watt of time-averaged power. Port 1 is excited by a signal of one watt, and the other ports are set to zero watts. After a solution is generated, port 2 is set to one watt, and the other ports to zero watts and so forth.
      WavePort вдувает в волновод мощность с какого-то возбудителя не показанного на схеме. если диаметр волновода позволяет на этой частоте ещё поддерживать определенную моду волны
        Всё равно не понял. В коаксиальном кабеле возбуждается волна ТЕМ. При установке порта волнового или сосредоточенного назначается интегральная линия указывающая точки приложения напряжения генератора( сосредоточенный порт) или направление вектора эл. поля( волновой порт). Для коаксиального кабеля оба порта дают почти идентичные результаты расчётов.
        И что значит нагрузка и генератор взаимозаменяемы? У них разные функции в этой схеме.
          Там не “Lumped Port”, там Lumped Element, по простому - сопротивление.
          Смотри пост#25.
            к Lumped никаких замечаний нет, к жиле и оплетке что-то соединено электрически.
            вопрос к WavePort
              Допилил вариант с трансформатором из 75 Омного кабеля. Надо сказать гемор еще тот, влияет все, и кабель за трансформатором, и внешняя изоляция, и толщина оплетки. Короче, этот вариант тоже по приборам только можно настроить, но настройка гораздо сложнее.
                Мyжики расшифрyйте пожалyйста. размеры. http://www.lan23.ru/forum/attachment...0&d=1512489843
                  присоединяюсь к просьбе.
                  И попробую ксв-метром найти ..., наверно точку запитки....минимум ксв же должно быть.
                    не точку надо искать, а волновод-трансформатор подгибать
                      Принцип простой, две оси координат X и Y. Каждая точка имеет две координаты, по ним и строится контур. Размеры по вертикали и горизонтали соответствуют координатам по осям Y и X соответственно. Координаты по оси X со знаком минус, откладываются влево, но можно и вправо, половинки симметричны.
                        http://www.lan23.ru/forum/attachment...2&d=1512477760 почему то мне казалось с этого фото, что размеры диполя как А4. Начинаю чертить...и вместо полного листа получаю фигуру меньше ладона. Думаю - обман зрения, чтоль. Внимательно посмотрев на кабель, конечно сопоставив, мона увидеть реальные размеры. Это у меня так или не только?
                          Размеры диполя (две половинки) 130х91 мм, чуть меньше А5.
                            спасибо большое, VM.
                            Если буду искать место запитки с минимумом ксв на 830МГц, диполь будет работать на эту частоту? Или все таки промасштабировать чуток увеличив его ? компактнвя будет lte850мимо - двое таких диполей - или на бэнд5. или на бэнд18.
                              Что-то я не знаю таких «бендов» 5 и 18.
                              Этот диполь не расчитан на прием, для приема нужны антенны с бОльшим усилением. Он специально построен для небольшого помещения, в качестве антенны репитера. У него хорошее подавление обратного излучения, поэтому получается «все в дом».
                              Я пробовал цеплять 3G через него и репитер (900 МГц, бенд-8), скорости никакой.
                                эти бэнды внутри 825-880ЬГц... У нас Билайн вещает lte на этих частотах. Ну а так, я думал, что антенны не бывают только внутренние или только наружные. Как попало, так и ставил. Может потому что сигналы сильные на крышах, все таки проделываю это в Ташкенте. Да и большмнстве своем ставлю китайские панельные, у которых предполагаю усиление нет даже 8-9ДБ. Но работают.
                                Вот что еще хочу - Ваш диполь пристыковать к сеточному рефу. Наверное получу небывалое усиление....нээ..? Эту конструцию направлю вниз через весь двор на 40-50метров , после репа.
                                кстати, сзади диполя заварю чтото металлическое, кторое уйдет вниз и выйдет сзади сетки
                                сапсем не фотогенично получилось - руки мои не такие страшые. Они вполне интеллигентно смотрятся...но в этот раз как у Отелло и КингКонга...так что пардон. Как будто год немытые
                                Последний раз редактировалось chilanzar2; 27.12.2017, 13:28.
